Window switch jump to put window up
SpecialK
My sister has a 99 Montana with the driver side window stuck down (Switch won't rock back into the up position apparently). Being Christmas eve and 20 degrees outside, she'd really like to get it back up.
Which wires on the switch are for power to the driver side motor?
Appreciate any help you can throw my way. I'm trying to help her from 200 miles away.
Hi!
There are several reasons and here are some ......
- Fuse (check if it works) - see image
- Wire break (check power supply +12 volts on the connector) - see image
- Defective switch (no contact) - see image
