98sunfirecanada
- May 30, 2011
Hi there,
I have a 98 2.2L and i just had a question about a vacuum hose. At the back of my throttle body i have 4 hoses. The big one to the brake booster, the one that goes to the canister purge valve, the one to the fuel pressure regulator, and then there is another one down at the bottom. The hose goes into the main wiring loom and around by the brake fluid resevoir. Then it connects into another vacuum tube (gray in color) at the brake resevoir and goes down into the driver's side firewall wiring loom.
Where does this vacuum line go? When i spray cleaner into it, it just blows back at me. If I blow into it i can't hear a hiss.
Thanks
Thanks
