Would the pontiac GTO 1967 motor fit on my transmisson i have?
  • Thread starter Thread starter *AZTECA*
A
*AZTECA*
My car is a Buick Lesabre 1968 and it has the original transmission.....and i am putting a GTO 1967 engine in there....V8 6.6L 400
would it fit....they told me it would but im not sure.....
The bolt pattern to attach it to the motor should be the same, but it sounds like you might have some trouble with the starter.
the engine will bolt up to your transmission, but you will still need motor mount stands, pontiac starter, all the brackets for the pontiac motor, and use the pontiac flexplate. i only have one question regarding this swap.........why? why not find yourself a good buick 455 to go into this car? plenty of power and it keeps the confusion down.
Yes the Pontiac engine will fit into the Buick and the transmission will bolt up.
Old, cadallic, pontiac and buick all have the same bell housing bolt pattern. Only Chevys are different.
Take your time and you will have a sweet running ride.
Best Wishes
jerry
it should drop right in. the only trouble you might have is the tranny cross member and i doubt it that you will have any trouble there either. buick, olds. and pontiac is the same as far as trannys concerned, chevys are different. i would say as long as the mounts hook up, it should be smooth sailing.
Should bolt right up to the transmission. Motor mounts, may be another story. Back in those days Buick had their own engines, Pontiac had theirs, etc. Should be an adaptor kit out there, if needed. Maybe someone like J.C. Whitney, Jegs.
