WTB 2002 Pontiac Montana a/c fan control
not sure why u want to buy a switch but if ur problem is that the fan doesn't work on certain speeds then it would be a bad fan motor resistor. a very common problem and an easy fix . If you need more info just ask.
steelcity is correct, you didnt say why you wanted a switch.
A/c fan speed control switch
Fan switch doesn't work on high speed,no. 5, and the LED lights for the the temperture control knob are out.
Looked at a pull a part place, and they only had up to 2001 montanas, and the switches are different.
Previous switch work off vaccum, my is a totally enclosed electronic control type
Previous GM fan switch experince taught, plus working for a Chev. dealer,
Fan inop on speeds below high, resistor pack, fan inop on high, switch.
New switch is 250.00....to rich for my blood.
