98sunfirecanada
- May 30, 2011
Having a little "issue" with the headlights...I know this is fairly common on these cars, but here is my scenario.
About 3 months ago i had the whole headlight wiring harness replaced from the bad spot behind the battery (where all the trouble normally is) right over to the passenger side headlight. It was all replaced and sealed with heat shrink. I also put in a new DRL relay.
I had been having the headlight problem where my right side high beam would not light up, and then eventually my both sets of lights wouldn't light up at all, so it was replaced and had worked great for three months.
Last week I noticed that my dash DRL indicator was still on even with my headlights switched on. So when i went out to inspect the lights i realized i had no low beams and when i flicked the switch for my high beams they would flash, but not stay locked on.
I DO have DRL, but that is all.
I pulled the DRL relay out of the fuse box and turned on my headlights, but there was no lights.
Any ideas?...Headlight switch?
