‘69 - ‘72 Front Rotors
mhnbonne
I have A ‘65 Bonneville with the first edition of the floating , single caliper brakes. I did this conversion by taking the entire spindle assembly from a ‘69 bonneville. I did this in 1973 and I have put over 200K miles on the car using this design. I cant even begin to tell you what a tremendous advantage I have experienced.
Rotors are now hard to find. I found a site that carries rotors for ‘69 through ‘72 and they say for Grand Prix.
Correct me if I am wrong but the front suspension design is the same for Grand Prix / Bonneville and Catalina?
They are all the full size models. The geometry did not even change from ‘65 to ‘69 Bonevilles
However, the rotors are different for each year from ‘69 through ‘72. I am curious as to what is the difference between each rotor.
I suspect that the only difference is that the spindles are different and the way that the calipers are designed. In other words, I could change the ‘69 design to ‘72 by swapping the entire spindle assembly just like I did to change ‘65 drums to ‘69 discs.
I ask this because the newer parts seem easier to find.
So is swapping the entire spindle assembly from a ‘72 to a ‘69 possible?
PS
I refer “Spindle” as what attaches to the upper A- frame and the lower A-Frame. The wheel axle is attached to this.
Thanks
Grand Prix is a G body, the others are B body.
The Grand Prix uses the same upper and lower control arm and steering knuckle/spindle as the Tempest, A body, for 69-72 per the Pontiac parts catalog from April 83.
OK,
Is there a difference between '69 and '70 ? If so, what is the difference?
I have a lead / link to a set for '70
Thanks
The part number for 69 is unique to that year only.
I assume you have checked with Ames Performance and Franks Pontiac Parts.
Rock auto has a rotor for a 1969 Catalina, however, the part shows as for "Safari" when the part comes up.
Isn't Catalina and Safari have the same front suspension as Bonneville ?
Thanks
A wagon may use a different diameter rotor. Measure the diameter of your rotor and compare with the one you are looking at.
