Daughters car (02 Sunfire 2.2 ohv 168k miles) just died yesterday at a stop light. Towed it home, thinking it may be the Pump. Because it cranks but does not start. I know i have to drop the tank, but before I do.. is there anything i need to know to test before I dig into this? As it may be something easier.
What has been done so far:
1) Crank sensor replaced
2) ALL Fuses checked and are good.
3) Replaced the Pump Relay with the AC relay - still no start.
* Do I have to relieve fuel pressure ( i did on my jeep when replacing the Fuel pressure regulator)?
* If so - how to do it?
* I heard you can pull a couple plug wires off one of the coil packs and crank to see if it arcs to test for spark.. is that correct?
Much thanks in advance
