can someone please shed some light on my overheating issue........car idles at 220' (normally 200') temp rises dramatically (240') while on road. new rad cap,new radiator, new stat, water pump working fine, both high and low fans operate when they should, no coolant leak (externally). oil, trans fluid clean, bled air from water rail (everything i read says bleeder is on thermo housing, not on my car).
Now for the symptoms.............heater works intermittantly, low coolant light on with full coolant (while engine cold and hot). engine temp climbs higher than usual in idle and would max out at 260' if allowed to. no sweet smell to exhaust or white smoke. both upper and lower radiator hoses hot to touch as well as heater core hoses. Replaced radiator (assuming water/coolant restricted inside rad) this morning as a sure fire fix based on all other causes checking out, to no avail, the only thing i can guess is that one of the smaller metal cooling lines is blocked with gunk or something, grasping at straws here. Running out of thoughts, and avenues to troubleshoot, if there is anything i missed please comment. I am not a certified mechanic, but have worked on and fixed every car i have owned in the last 20 years.....this one will be no exception, but a little push in right direction will be greatly appreciated, thx for reading
