check all the connections at the lights including grounds. You also should check for loose battery connections both at the battery and ground and starter.
First I've heard of it. Anything else that flickers ? Parking lights ? Maybe a bad or loose head lamp relay ? Or like Mel said loose ground/wiring. Something that's common with both head lights . Good luck keep us posted.
