05 sunfire
richoll
so I have a 05 sunfire and I've been having problems with my front speakers I have replaced them 4 different times already and each time the damn speakers bust or stop working. I don't play my music loud there is no amp going to them just the stock radio.
Another problem is the aftermarket radio I bought its a pyle and when I got the harness for it and went to connect it the damn radio didn't turn on I know I wired everything the right way cuz I have a wiring diagram ive tried looking everywhere for answers but so far no luck.
are you using the correct ohm rating speakers for the radio?
is the Pyle radio new or used?
Not to sure the original ones were 8ohm and the new ones are 4ohms I didnt know that was a factor thanks
The pyle radio is new
if you are installing the wrong ohm rating speakers that is why they are failing.
Either the Pyle radio is defective or not wired correctly, have you contacted them with this issue?
Ok so I'll get some 8ohm speakers for the front see if that fixes the problem
As for the radio im pretty sure that its wired correctly I do have a wiring diagram so I think I will get another cd player since I have warranty on it and we will see what happens
Thanks again for the advice
