I put in a different battery. Still nothing.Do you have a multimeter?
What is the battery voltage?
Are you sure the battery cables are clean and tight and have no corrosion where the cable meets the terminal under the insulation?
Do you have a multimeter? NoYou made that clear in your original post.
Can you answer the questions?
New starter relay and same.Owners manual page 5-87 shows a starter relay.
Try swapping it with another identical relay from the box.
