1955 Chieftian
  • Thread starter Thread starter Pont56
P
Pont56
I have a 1955 Chieftain and need to know if the front end of my drive shaft will fit into a newer transmission? Either if you know or if there is a web site that has that sort of info please.
Pont56@aol.com
Absolutely not. The only thing you can do is take it to a shop that does driveshafts and have them weld a new end on and balance it. Usually not too expencive (2 or 3 hundred at the most, the local shop here will shorten and balance one for 150).
