willongboarder
Hello,
I've got a 65 LeMans with a '72 455 in it, and am having issues with the headlights.
The issue started the day I drove it home, when I hit a deer... both passenger headlights were broken, which caused the driver's side headlights to also stop working (that was odd to me, that they run in series). I took the high beam off the driver's side and put it on the passenger side and was able to drive home, albeit a bit rude to have one cockeyed bright lamp. After being repaired, the headlights worked fine, but over the last winter they stopped working.
Checking with a meter, I don't have power at the lights, brights on or off, but the running lights do work in the halfway (switch) position. Brake lights and rear running lights work (half and full switch extension), as do the interior and exterior turn signals. I've also disconnected the plug that feeds the lights (in the engine compartment) and don't have power there either.
I replaced the switch hoping it would solve the issue and also because it was finicky and wouldn't always turn the running lights on (headlights didn't work with the old switch and still don't, with the new ACDelco D6251D).
I know the stereo had been replaced before me with an aftermarket one, but the original is in now and not hooked up (waiting to get the right connector from Ames). I say that because I've read that maybe the ground wire from the stereo has to do with the electrical system. That wire, which is gray and comes off the top of the stereo, currently goes nowhere.
One thing that is different about the ACDelco switch is that it has a dedicated ground terminal on the outside of the switch module itself, a prong/blade like the others that would accept a ground wire if one existed in the original setup. I figure maybe I should run a proper ground over to it to see if that helps. I did try running the ground wire from the clock to the dash with no luck but I don't trust the connection to the dash.
So, this was a long winded way to ask if anyone has any experience with the lighting setup on these cars, or experience with using the new ACDelco switches.
Thanks!
Thanks!
