Good Afternoon,
I own a 1968 Firebird 4 speed Convertible with a non-original 326 engine. I believe the engine is from 1966. It has what I think is a Carter 4bbl AFB Carb. I have an issue, I think with head soak and am in need of a 1/4" phenolic spacer with associated gaskets. My issue is that I can't find the correct size spacer and gaskets. I have attached a photo of the original carb gasket with associated measurements. I can't even a correct replacement gasket.
I have purchased a couple of spacers and gaskets and none had the correct barrel sizes.
Can anyone help me with this, what to get and where to get it?
Thank you!
Phil
Thank you!
Phil
