robert n
[Hi all,
My fiero doesnt idle well, Its OK when it first starts but proceeds to slow down and will eventually stall. It starts up but will stall with any load ( like putting it in gear)
I have replaced the EGR valve and the MAP sensor and fixed a couple of vacuum leaks. Its still the same
I dont get any trouble codes and I do get code 12 when I ground the test terminal
It runs great as long as you give it some throttle.
HELPSHIZE="4"][/SIZE]
