1987 Problem child
  • Thread starter Thread starter csi-diana
C
csi-diana
I will be driving and all of the sudden it will stumble and drive like its only on two cyclinders.. Then when I shut it off, it won't start until I let it sit for about and hour. I have replaced plugs, wires, both coil packs, crankshaft senor, 02 sensor, ERG valve. Can anybody please give me some ideas. I know I need a voltmeter, but all I have to use is a test light.
Thanks Diana
When you replaced the coil packs, did you replace the ignition module as well Diana?
No I have not replaced that. Is there a way to test it without removing the whole assembly? I also forgot to add that the radiator and starter have been replaced. Thanks
