K
kurt w
automatic.? Here are the things i have done so far. Replaced spark plugs, plug wires, distributor cap and rotor. checked the air injection valve and air pump. Checked the timing. no obvious exhaust leaks before the cat convertor. The car does reek of fumes, smokes and runs a little rough on cold start up. I have been told it could be a bent push rod or valve. Any advise before i start leaning that way????? Thanks ~ Kurt ~
