I have put a new head gasket in my car and it runs rough. The turbo pressures up and it starts to back fire a little. The timing is set to 10 degrees and it doesn’t want to rev up. I have tourqued the head as per factory settings. Is it possible the head could need to be tightened more? Or has anyone had this issue or how can you check the valve set?
