1991 3.1 trans fluid dipstick tube
GeorgeT
Member
Hi everyone, just bought a 1991 sunbird and when I checked the trans fluid the whole dipstick tube came out. Is it held in by a bolt or some sort of O-Ring.
Thanks for your time.
You don't see anything along the length of the tube indicating a support bracket broke off? There has to be a seal of some kind where the tube attaches to the transmission.
Ok thanks, and would that be an O-Ring? And I’ll check tomorrow as it’s dark out now
I will take a look tomorrow but, as for the seal is it an ORing or a specific seal like a multi-lip?
Thanks for the reply
Look at Rockauto if you want an image of the seal
Bolt holds it on, must of fallen out or mounting bracket may be broken....
Doug in P.R.😎
Ok thanks I will check that, thanks for the help everyone appreciate it
