i just replaced clutch on 91 grand am 2.5 - all went well - when i removed the clutch the throwout bearing had almost worn through the springs on the pressure plate - i thought this was odd assumed my son had been resting his foot on the pedal and forcing the bearing to run all the time - however after replacement i see that the slave cylinder rod is actually pressing the clutch fork to the pressure plate even without foot on pedal - pedal comes all the way up and starts moving the slave rod as soon as it's touched - there is no adjustment on pedal so what's wrong - slave cylinder bad? - thanks
