1991 2.0l no spark at coil, the fuel pump comes on and the injector pulses. retrieved trouble code 42. There is 12 volts supply at the coil and the C wire of the ignition module. Replaced the coil and ignition module, still no spark. The rotor turns when cranking so I ruled out the timing belt. Was going to try the pick-up coil next. Any suggestions.
