R
rharmyguy
I have a 93 Grand Am, 2.3L. It was running fine up until about a couple weeks ago. What it does is it goes down the road and seemingly "loads up". This causes it to chug, or jerk real bad going down the road. If I let off the gas and re-apply, it helps for a little while. It only does it when I'm going at a set speed. When I give it more gas it seems to level off for a bit. Also it just starting getting the "Sooty back bumper" from the black smoke. I really can't pin this down whether is an ignition or fuel issue. My best guess is that the chugging happens right before the car is ready to shift into the next gear. Could it be vacuum and would that cause the fuel soot? I'd figure if it were fuel, cleaning the injectors would be a safe fix. Everything seems to be working 100%. If the ignition, the plugs would show which cylinder was missing. It has me stumped! Any thoughts??
