I got an oil leak on the top of the engine on the drivers side right near the oil pressure switch. I took the switch off yesterday and the entire plastic housing inside was filled with oil where the harness goes into and I replaced the switch. Now I have a small drop of oil that runs right directly underneath it but I cant pinpoint it. It's a small drip that happens every 20-30 seconds. I also have oil wetness on the back of the engine I believe where the valve cover is. There's also oil around the front of the engine where the fuel injectors are. I also have a slight misfire I believe when I go to accelerate.
Does this sound like a leaky valve cover gasket? and it causing a misfire too? I'll look more tomorrow.
