Can someone tell me how to replace bulb in this particular model? I have a friend who needs this replaced but I just can't figure it out? Thanks for any help
I assume you dont have the car at the moment and checked whether you can access the bulb based on the instructions for the 99? It has to be similar. Just so many ways you can access a bulb.
She has the car here at work, just figured it out, had to remove 3 ea 10mm bolts 1 on each side of headlight top side and 1 in the middle to a bracket and then whole assembly slide out. Thanks for help!
