jacksonvillain
- Dec 17, 2014
Ok so as the title says I have this 1997 sunfire. When I stop it will drop down to approx 800 rpm. (im guessing as it isnt digital but just under the 1000) Sometimes I will stop and it will drop down to say 5 or 600. Sometimes it will stall. I replaced the TPS and IAC today and it seems better but still wants to die. And yes, I reset the computer. It has new delco plugs and I have listened to the injectors with a screwdriver by putting the tip down on them and listening. They all seem to have the same rhythm. Fairly new fuel pump. Is there an egr or something that could be causing this? I also checked the check vave going to the power brake booster. All the vacuum lines. Still can't quite figure it out. Other than that it runs beautifully
