daddys gurl
- Sep 18, 2010
So i had to replace the motor in my sunfire. I basically had to build it from 2 motors. It's got the block from a 2.3L and the head from a 2.4L which the blocks from both are the same. I had to use what I had. I originally bought a 2.3L motor thinking it could work, wrong. There is no place to plug in the EGR on a 2.3L and I couldn't afford the comp and shit I would need to make it work. So I did as stated above.
Well everything was going all fine and dandy until I had an oil leak from between the valve cover and the timing chain cover, I had the gasket in stupid. Well I fixed that and made sure the gasket is right. The timing is spot on. But I had to get a different bracket for the throttle and one for the EGR cuz I lost them. Replaced both of those, and put a new Idle control valve on.
When I started it with the oil leak it ran great but it was leaking oil. When I started it after I hooked everything up again it idled at 3500. This motor was running good before I fixed the leak. How do I fix it? What are all the possibilities it could be?
And please guys only answer if your serious, just because I'm a chick it doesn't mean I don't know what I'm doing. I might not know the proper names but I can get it done.
I will not take it to a shop either. Just tell me how to fix it.
