Jeremy_steven10
- Sep 29, 2015
Ok, highway driving, temperature rises to 222 degrees, no engine fan. I changed thermostat, coolant, checked power to coolant temp sensor (5 volts), getting power to fan (checked), fan works but when on highway cruising, fan doesn't want to work. Cold coolant level is proper. Also changed coolant temp sensor with a used one wrecker. Maybe try new brand new sensor next. But ohms on sensor seems to be ok. Temp reading is there. Fan doesn't kick on with a/c either. I have to crank heat to keep highway driving safe temp wise. Also disconnect coolant temp sensor to run fan constant. So I read I guy reset PCM by disconnecting battery and changed coolant temp sensor and that worked for him, so I'll try that now. And also had shop check cooling system pressure, they said was fine.
