mdurnil457
As the title says, 99 sunfire starts and will run for 2 seconds and stalls.
I've tried the theft reset and a new ignition cylinder.
The theft light used to blink, did the reset and now its on constant. I'v tried and retried the learning procedure, but the light simply stays on...
I've checked and it is the fuel that is the issue. It primes like it should and fires right up but then the fuel pump is cut off.
Also all dash lights are on and the tachometer doesn't work.
I've kept the car running,aying starting fluid and all lights ( Check engine, Coolant, Oil Etc...) remain illuminated.
Is this a bad PCM?
Thanks!
Is this a bad PCM?
Thanks!
