S
stkpiler
2000 Grand Am 2.4L cranks but won't start. It has good spark and injector pulse. the fuel pressure seems good and it won't start with starting fluid either.It sounds ok when it cranks over and it has 180 Psi compression in each cylinder.The security light is not on and that system seems to be operating properly. There is a strong gas smell at the tailpipe so I suspect either the ECM is not controling the injector pulse properly or that the timing chain is somehow off, but I don't see how to check either one of those problems. Any help with a timing chain check or ECM test?????
