Dane Allen
- Mar 26, 2013
Overheating. My cooling fans don't come on when the coolant gets to 220. Both work with A/C and primary fan worked normally until recently but no longer. Just replaced the Coolant Temperature Sensor to see if that was the problem, it wasn't. Checked all fuses under the hood. Heads and intake machined recently, new top end gaskets. Replaced poor performing radiator last week and has made a significant improvement in coolant temperature control, almost don't need the fans. No leaks and new hoses all around. Heater blows hot and keeps the engine from overheating as does running the A/C but without either the temp heats to 220-230 and coolant boils out. What next?
