My aztec is having trouble starting. The symptoms are:
Car stuck in park(clicking sound in dash when I hit the button on the shifter)
All lights go off when ignition is in the start position but nothing happens
Key is stuck in the ignition
Warning chime goes off CONSTANTLY and heads up display says CHECK GUAGES
I have 2 bcms and it does not matter which one I use the issues are the same.
I am leaning twards a bad console shifter but not sure if that will cause all these problems. It started all this at the same time.
Any help would be great
Thanks
Thanks
