So I've started having an issue with my drivers side sliding door. Well two issues but the second is manageable, the first not so much.
First issue: on occasion the outside handle will lose the "electric resistance" and basically "flop" in and out (I hope that makes sense) basically like the handle on a non-electric door or a car that is locked... Anyways when this resistance goes away, so does the doors ability to latch shut. Which is the problem. We can disable that side from the control console but the handle is still screwed up and if we try to close the door it just bounces back open. After a while it will star working and latch shut again, but in the meantime since the door is basically stuck open, it's unusable. We've stopped using the door and it doesn't magically open, so it seems to be a closing issue.
Anyways I've looked for videos on replacing the handle but don't seem to find any for the year... Just the front doors.
Second issue: occasionally the handle will get really stuck and have lots of resistance and won't open or unlock.
