K
Kel T
I have a Pontiac grand am 2001 which will not pass an inspection.. It keeps getting the code p0507- high idle speed. But my car is running fine at around 850 rpm and not higher.
I have taken it to many different mechanics but no one can give a definite answer (or the same answer). I have reset the computer and changed the idle control valve, but still the code returns.
I have been told that it could be a problem with the computer- as the idle speed appears fine, and there has been no related problem found... just the p0507 code...
Any ideas as to what could be the cause- or is anyone in the same situation??
Thanks, i would appreciate any help...
