Hi all. New to the forum here.
My sister has a 2002 Grand Am SE that she purchased about 6 months ago. Everything on this car has been wonderful and it's super fun to drive...up until a week ago.
As she was leaving a shopping mall to return home, the clutch pedal stuck to the floor when coming out of the parking lot. Upon returning it to the upright position, I pressed it down again, and again it stuck to the floor.
Upon further inspection I saw clutch fluid leaking from the bottom inspection hole in the bell housing. Once I determined how these transmissions are designed with the release bearing and slave cylinder as one piece, I concluded that the slave cylinder had developed a major leak and required replacement.
I'm in the middle of removing the transmission at the moment and will be doing a full on clutch replacement to also include new slave and master cylinders. I also removed the clutch master cylinder thinking it might be that. When I pushed in on the piston in the clutch master cylinder, it does not self return. This leads me to conclude that the clutch master cylinder does not have its own return spring in it and thus relies on back pressure supplied by the pressure plate upon releasing the pedal to push fluid back up to the master cylinder in order to return its piston to the non-pressed position. This means that the system must be full of fluid and completely bled out in order for the master cylinder to function 100% properly.
So the question that I have is -
When you have a completely dry clutch actuating mechanism on these vehicles, how does on go about doing an initial bleed of the system until there is enough fluid in the system for the pressure plate to return the master cylinder piston back to its resting position? Any and all posts regarding this matter are welcome.
