2002 Pontiac Montana Vehicle Speed Sensor
politicaldog
Hello All,
I am going to hook up a vehicle measuring device for my work and it has to be soldered into one of the wires connected to my VSS and counts pulses, uses an algorithm and converts to feet. These units are accurate as I have used them in other vehicles. I have found the unit and the wiring on the trans-axle but would really be thankful if someone could tell me where this wire ends up in the engine compartment for easy access.
Thanks Rick
it connects to the PCM located under the air filter box in the engine compartment. You will need to find a wiring diagram for more detail.
Hi !
The wire goes from the sensor to the connector C1 (ECU) to the terminals 64 and 65
(See picture)
Moscow to the rescue, thanks Sergei!
