jimmywalters
- Oct 28, 2015
Have a 2003 montana. When I shut the car off, it sounds like the coolant is boiling for probably 5 minutes after the car is totally off.
So, I turn the car off, and usually within 30 seconds or a minute I will hear a boiling sound that seems to be coming from the radiator. It will continue for about 5 minutes and then slowly die out. This is with the key out, I'm totally outside the car and the doors are locked. Car is 100% off.
My car doesn't seem to be overheating at all. I thought maybe the coolant level was low but it seems exactly right in the reservoir and so I checked on a cold engine and took the fill cap off, and coolant starting coming out the fill cap so I know there's enough coolant in the system. Not sure why it was so full, full enough for coolant to spill out when cold, but even losing the amount that I lost when checking that hasn't seemed to help the problem. So at this point I'm convinced that it probably has the right amount or possibly slightly over the right amount of coolant.
Is this normal for these cars, or any cars i guess? I've never noticed any of m other cars sounding like the coolant is boiling but maybe I just never noticed before.
If this is abnormal, what could be causing this?
Thanks!!
Thanks!!
