My coolant gauge is usually like the first image. Lately, especially after driving on highway and slowing down to in-town speed or if stopped for awhile, sometimes spikes around to what the second image after I restart my van. This issue has started up within the past 4-6 weeks.
Usually, I find my coolant tank is down a little when it happens. I pour some coolant into the tank and the gauge goes back down to normal for awhile. Coolant does seems to get eaten up slightly after highway driving. No sign of a leak underneath.
Earlier in month, I have replaced my thermostat with a new failsafe version and had a flush. Also it passed a short pressure test. Heat appears to be still okay, although it doesn't heat up fast at low heat settings. AC is fine. Also, a cooling fan sensor was also replaced. Radiator appears to be fine.
I plan to have it checked again with a full pressure test. Not sure what is causing it this issue.
