2005 Sunfire Knocking Noise
j&awar
2005 Sunfire Knocking sound whenever not on smooth roads engine runs great manual transmission shifts good also 100% sure it's not the engine on smooth roads there's no noise at all on uneven rough roads usually at speeds 40 and below the slower im driving the louder the Knocking sound is rpms are stable not throttle related cars getting over 30mpg is this probably something the suspension? I'm hoping for a simple not too crazy expensive fix literally just got the car thank your for your help!
You can't pinpoint front, rear, left, or right?
You didn't have the car checked by a mechanic?
Haven't been able to get a shop this hurricane that just came though really messed our house up pretty bad power and water still out the noise is def coming down the front passenger side and only when on bumpy or uneven roads
Check for my missing or broken front stabilizer link. Also worn strut.
ending up taking the car in
had some dry rotted motor mounts and bad tie rod ends sway bar end links had to be replaced also
but cars rock solid now and much happier
