koolwhizzer
- Mar 8, 2011
Hi
msmith1956 I see what you are talking about. The harness that comes from the sensor plug to the plug that is mounted on the in my case inner fender well. I will see if i can get to it and see it there is a visible break or i will use my multimeter to see if there is continuity. I will keep you posted on the outcome. Should i try all the corners or the 2 that the dealers identified?
