justindorval
- Jun 6, 2017
We have a 07 Montana that intermittently shudders when accelerating from a stop and only from a stop. Does it a couple times a day MAYBE some days it does nothing. We have been told its 100 different things....Possible transmission although its been to three shops and none have been to pin point a problem although every time a mechanic drives it of course it doesn't happen. Motor mount was replaced... not the issue.
The ABS/Service traction control light are on because it needs a new bearing. have been told that may be the problem because the ABS is malfunctioning.
What is the actual problem....Why does it only sometimes happen. once it shudders and its on the road it drives fine.
