you tube has videos on thermostatic housings bleed and waterpump.I have same issues, swapped core last summer, smelled AF once in a while, did the cheat where cut metal lines under dash and spliced with short pieces of hose, no need to pull whole dash that way, just part of console and gas pedal. I could not locate the thermostat housing bleeder, only found the water pump one, swapped water pump at same time and that front engine mount, she was riding low...
Anyhow will look again for bleeder on thermostat housing.. -25F to -40F wind chills for the next week starting today, hope there was trick here to find..
Had same issue, if rev up heat, if idle, she cools down, haven't brought thermal gun out yet, but hand test thought both hoses were close to same temp, hot...
My back certainly hopes there isn't similar issue with bad head gaskets, temp gauge sits just under half, drove for a year now, think would know..
With pandemic, did not get a lot of miles in to know had heat issues until few weeks ago, only drive couple miles every other week for supplies.
i hope not the heads
