D Berry
I've been searching around the net looking for info on the interchangeability of parts between the 301 and other Pontiac v8 engines. I suspect that I have a blown head gasket, it runs fine and doesn't overheat but it does have bubbles in the radiator while it is running. I have found information that all the Pontiac engines 326 through 455 have the same block as far as dimensions are concerned and heads and intakes are interchangeable. He also claims that the 301 and 265 also use the same block dimension wise. Then some folks claim the 301 and larger displacement engines have interchangeable heads and others claim not. One guy says that the heads are interchangeable but then the intake won't fit. Well if the blocks are the same, dimensionaly, and the heads are also, then why is it the intake won't fit. Does anyone know, Please. I'm thinking of getting a pair of heads and having them cut and valves done so I can just swap them with little down time. I thought about just changing the engine for a larger Pontiac v8 but finances are tight and finding a decent running engine around the St Louis south/central IL region has so far proven fruitless, especially since given my health I'll probably have to pay someone else to do the swap anyway. Please does anyone know the real answer?
