" All Ram Air cars were shipped to the dealer with the Ram Air Baffle, Shroud, Air-Filter, Seals and Open Hood Scoops shipped in the trunk. From ’67 until early 1968, the parts were removed from the trunks and returned to the parts-crib by guards/inspectors while preparing to ship as they suspected theft. This discrepancy was corrected and it is assumed that parts were forwarded to the dealership for installation.
* All Ram Air cars came with a standard 4-Blade Rad’t. Cooling Fan unless optioned with the ‘Flex-Fan’.
* Ram Air Firebird’s ordered with the Ram Air Option and Underhood Lamp were modified at the Dealership in order for the Lamp Assy to clear the Hood Baffle. The Lamp was moved slightly outboard to clear the Baffle.
* The Underhood Structure req’d. a modification to the RH side near the Scoop in order to allow proper fit/sealing of the Ram Air Baffle & Seal. This was performed at the dealership while the Ram Air parts were being installed. A small section of the Underhood Metal was snipped away. In most all case’s, this was a crude alteration and is usually quite noticeable"
The GTO forum says that Ames or OPG should have the instructions but charge $40 for them?
Cant find instructions as of yet, here's a pic of one............
Doug in P.R.
