palawman30
- Jan 11, 2014
Ok guys
I had drums all around... I did the conversion to disk on the front. I put in a new booster with master cylinder and prop valve...the one for disk/drum setup..
Also put in new control arms and all front end suspension parts...
Problem
Ran brake lines to new calipers from the lower brake trunk near bottom of engine and have no brakes...
Question
Is that lower brake block a metering valve for drum/drum setup and can I now totally eliminate it because I have prop valve at master cylinder?
Run new lines from New prop valve directly to calipers on front and long run to rear?
Problem
Question
