72 Catalina heater fan
bugsy1955
Hello All. Sounds like the heater fan (?) is constantly running and never turns off. Any suggestions???
it's probably supposed to do that for ventilation any chance you have the owners manual?
From Steve's Nova Site:
"Some of the GM cars were designed to run the blower on low speed all the time. It was part of the "flow through ventilation" started around 1968 to keep fresh air moving through the cabin. Around 1975 the fan was able to be shut off with the switch but GM still had the fresh air movement, it was done with air moving into the cabin while the vehicle is in motion."
A/C car?
Could be the relay: ( pic below)
Doug in P.R.:cool:
Thanks for the input. The car has no AC. When I figure it out, I'll let you know.
