rverso1
Looking for some help on a wiring problem. 77 firebird T/A. The coil has voltage going to it when ignition switch is in off position. Even when switch is removed there is a slight voltage draw to the coil. I traced the pink wire from ignition switch and found it splits into 3 pink wires. One goes to the block then out to the coil, the other two go to fuse block/fuses. Has anyone ever run into a slight volt drawl issue, and could point me in a direction to go, thanks.
Bob
Bob
