84 sunbird 1.8 turbo fires but no run
  • Thread starter Thread starter G-630117
G
G-630117
new fuel pump, new fuel pump relay, fuel filter, plenty of pressure to fuel rail, acts like no fuel getting through injectors is there an injector relay or switch that could cause this
Prime solenoid (2 seconds),should hear it come on when turn on the key. You also could have clogged injectors/screens which would require removal to clean. Make sure you are getting power to the injectors also..
Doug in P.R.😎
Are you sure you have spark at the plugs?
