codylewis70
- Nov 5, 2022
Replaced previous distributor w MSD Ready to Run (8360). Engine is nearly new 383 Stroker but gauges in the car are original. Tachometer worked fine before the new distributor. Mechanic that installed the new equipment said that I should be able to find an interface part that would help those two devices communicate/work together. All connections are secure and mechanic did check with an external tach to make sure that his still worked when we found that the car's had stopped. I'm hoping that someone on this forum could steer me in the right direction... Thanks in advance!
