I have a 88 formula that is running rough. I starts and idles fine but when I try to give it fuel it acts as if it is starving for fuel if I put it in neutral and shut the car off then turn it right back on it will run fine for a couple miles and then it does it again. I have changed the fuel pump the fuel filters rebuilt the throttle body. What else can I do to make it run again?
