HELP!!!!!
my car dose not want to stay running. seems to idle fine till it warms up then quits. when car is idling i throttle slowly and reaches around 2000 to 4000rpm, then it starts choking. when i hit the gas fast, it chokes. when the engine is hot it will stall and not start again till it cools. i have tested the fuel pressure and it reads 38.5 to 40psi when idling. from a handfull of mechanics that is fine. tested for spark (that is good), also replaced gas filter.
so i am wondering if anybody else has had this particular issue and what they did to fix it. please indicate if it is from the manual or not. thanks.. i will be posting new areas as i encounter them. here is a picture of my engine incase you need to explain a location or part..
thanks, John
thanks, John
